figured I should start a new thread on my cam blot castor. Replay to last night driving home on the freeway cam bolt slips again and my front lower control arms are loose and moving around, the jeep is almost uncontrollable and even had a couple seconds of dw luckily as soon as I let off the gas that stopped. Parked the jeep and in the morning bought a digital angle meter at osh for $20 that worked pretty good and checked the angles, castor was neg 2.7.
Had to cut out the bolt on the passengers side as the nut was frozen to the bolt. Put in the new bolts but the adjust tabs were a tiny bit deformed and I could only get roughly 4.7 to 5 positive on each side. My gauge wouldn’t sit flat on the back of the pinion, but the angle from the top of the diff at the rear looks to be true 90 and if so the angle measured around 8 positive if I’m measuring correctly. Took her out on the freeway and the handling felt as good as it ever has and didn’t notice any vibrations. Not sure if an alignment shop could set anything different and it actually feels better than when I paid 4wheel parts to do the work for me, so I might just see how it drives for a while. Am I missing anything?
