Ok is it just my imagination or can a new throttle body position sensor really make this big of a difference? Recently installed a new stroker, run 35 class C with 3.73 and thought it was an awesome improvement. I has had a small surge every now and then on my trips to and from work (4 hour drive) but got really bad on the way home this time and had the engine light pop on. I thought I got a big slug of water in my last fill up. Found out here that you can’t read codes with the key and trip reset trick on my 99 so half way home I am over at an auto parts for a code read. And $60 for the sensor then $20 for the stupid torx set (the one set i left at home) and I am on the road again.
Thing is she was way more responsive now at least it seems so to me which may be all in my head, but one thing is fo sure I no longer have to goose it to maintain speed in 5th gear to cross overpasses or bridges, just a slight feather of the gas peddle now and she will accelerate up them.
Can’t believe that little black box made that big of a difference.
Sent from my iPad using Tapatalk
