Any help would be greatly appreciated found these cheap one needs a little body work and a door panel just trying to confirm bc I have to drive 2 hours to get them
Ok so they are for sure tj and picking them up for $250TJ doors , how much ?
I’ve got a driver side interior panel. It is tan tho…will need to be dyed if you want gray.So they are for sure
How much?I’ve got a driver side interior panel. It is tan tho…will need to be dyed if you want gray.
Kinda what I was thinking little body work and paint don’t have to be perfectTj and 250 is a good price even though they look rough
You can use YJ half doors, but you need to change the striker pin on the tub to the YJ one.Is there a difference in the dimensions of the doors between a YJ and a TJ. Otherwise could you run a Yj door on a TJ with or without the interior panels.
