In almost 2 years, I’ve put ~19k miles on this Jeep and have never had death wobble. After some recent changes, it now happens very often. On my way up to hot springs last night I lost count of how many times I got DW.
Those recent changes were:
Pitman arm swapped from dropped to OEM
1.25” BL
1” MML
Fuel pump changed
Alignment done
Tires rotated
I started getting death wobble before the alignment and rotation, which I thought would fix the issue since I had excessive toe-in, but if anything it happens more now.
I am trying to narrow down what’s causing the DW and correct it ASAP. Losing control of the vehicle and having to slam the brakes to a near stop to regain it (on the interstate) is absolutely unacceptable.
My question is, has anyone else experienced death wobble after changing from a dropped pitman arm to an OEM? I can’t imagine that the motor or body lift would cause me to suddenly get death wobble all the time. The pitman arm is the only steering-related component I changed.
1.25” BL
1” MML
Fuel pump changed
Alignment done
Tires rotated
