So first off I fully understand why PS sliders mounting to the body mounts sucks, and that is because I have them on my LJ. Structural integrity and all that. I also get popping all the time just driving around town, let alone on the trail, and they do not sit flush against the tub. There are gaps all over and I can tell its pulling on the sheet metal. I had all the mounts loosened the other day and was working to try to align everything better, but ended up just contemplating pulling them off and buying a new set. However, I'm hesitant to drill new holes in the side of my tub. The likelihood that any of the bolt holes will line back up is probably very slim, although I will admit I have not called anywhere and gotten any measurements.
So as I'm sitting here drinking my coffee and looking at sliders, wondering if anyone has cut out the portion that mounts to the body mount and mounted them directly to the bottom of the tub. It doesn't look like they sit flush against the underside though, but hard to tell. A tough experiment to do because if it doesn't work the sliders are completely worthless...
