I am replacing my motor mounts and I need to replace one of the bolts that connects the mount to the engine. The existing one is metric and reason I can not use a Std. non-metric bolt of the same size. ?
Metric and standard bolts have different threads and therefore are not interchangeable. If you attempt to use one, it will cross thread and bind.
I am good I was able to find a metric bolt at Bay Bolt the right size. I love the idea of mixing metric and std size on the same vehicle. WTF
Jeep did!
Guessing you don't pay much attention or you don't work on the rig much while you're paying attention? Front bumper, 6 larger bolts are 1/2-13, 4 for the swaybar mounts are M10. Belly skid is 1/2-13 for early, M12 for later, rear bumper bottom bolts pointing up are 1/2-13 for early rigs, M12 for later. Gas tank fasteners are 5/16-18, trans mount bits are M8. They switch back and forth all over the place. Tossing a standard bolt in the motor mount wouldn't bother me in the least as long as it was a decent fit and grade 8.I love the idea of mixing metric and std size on the same vehicle. WTF
Why do they call it a motor mount when it’s supporting an engine and not a motor
For the same reason you don't tell someone to engine your ass on outa here.
For the same reason they don't call Detroit, Engine City.
For the same reason all your gear head buddies aren't called Engine heads.
