I recently swapped in some 2003 rubicon axles into my 1999 jeep wrangler sahara. As my friend and I were wiring up the lockers we noticed the rear locker indicator wasn't working, so we pulled it out to test it. When I put it back in the axle and drove it I noticed the rear would not unlock. After a google search we realized that it is necessary to pull the carrier to reinstall the sensor/indicator. Had I known this beforehand I never would have removed it. To unlock the rear we just cut the end of the switch off to plug that hole. Basically my question is can I use the locker without that sensor/plunger installed without having to worry about messing something up on the locker? I don't feel comfortable removing the carrier so I'd have to pay someone to fix this issue which doesn't sounds cheap. I'd rather not spend a bunch of money to have a light telling me a locker is on, but I also don't want to mess up the locker if this indicator is necessary to its function.
Thanks in advance for your help!
-Jamey
-Jamey
