I know the Harbor Freight 12-ton press is fairly inadequate, as far as presses go. But, is it physically large/strong enough to press the bearings on Dana 44 axle shafts?
Tonnage is fine, don't press both at the same time. Do the bearing which is very low tonnage and then do the shaft collar. If you chamfer the leading edge of the shaft journal with a Scotchbrite disc and turn it into a smooth radius, the sharp edge won't hang up inside the collar and drive the tonnage way up. The biggest problem is enough length under the press bed for the shaft.
I've done it on the 12 ton. It was terrifying but it did the job. If you can get the 20T.
The length/work area is what I am most concerned about.
Did you have to do any modifications to the press to get the axle shaft to fit? It looks like it will be a very close fit.
My problem is I already bought the 12T (because it was on sale) and realized on the way home that the axle may be too long to fit. I could return it, but if it's big enough to do the job, I'd rather have the smaller 12T due to limited garage space.
Go with the 20t if you can swing it. With Blaine's suggestions, the 12t might be safe but the lighter duty press is flexy AF in my experience.
All you have to do is set the legs up on something to raise it higher. Not a big deal at all. I had to do that to my 20 ton to get some of the longer 9" shafts in it.
Thanks. That sounds like a good safety net if it doesn't fit for some reason. I thought the brace was in the center, and it wouldn't matter if I stacked it up on blocks. I haven't assembled it yet, and that's hard to see in the photos.
I'm not familiar but if it is just the side to side brace between the lower legs, move it out to the ends of the legs and add one just like it to the other side.
Do the HF presses still come with cast arbor plates? If so, from personal experience I recommend getting a set of steel plates.
Years ago I had a 20 press which had cast arbor plates. One exploded on me (I think while pressing on an axle bearing), and a big piece went right past my head, 40+ feet across the shop, and through the drywall near the ceiling. Scared the hell out of me.
I picked up a set of steel plates from Swag.
I wish I could swing the 20T, but the extra $100 and footprint in the garage is a definite negative for me.
I know they have made some changes to them to attempt to alleviate the complaints but I don't know how successful they have been. I broke both of mine on the first axle bearings I tried.
I've loaded mine pretty heavy (stalled the bottle jack) and my plates have held. I still think about making some new ones, I have a piece of scrap sitting around that would be perfect...but it hasn't happened yet. My press is about 2 years old, I think.
