Faced with possibly replacing the control panel and blend door actuators on my 2002 TJ. Prior owner had disconnected the vacuum at the engine. I haven't tested it yet, but I am assuming it was disconnected due to a vacuum leak in the lines, blend door actuators or control panel. Most all of the aftermarket control panels are for TJs with a/c. Can these also be used for those TJs that do not have a/c?
Does anyone know what the actual differences are between the Mopar numbers 55037472AB and 55037472AA or Standard Motor Products HS-372 and HS-373?
Thanks!
Kim
Thanks!
Kim
