Cant find front sway bar link
jqkitinge
Indiana
Recently purchased a 2000 TJ with an unknown amount of lift and the front sway bar links are shot. The current ones measure 11.5" eye to eye and I cant seem to find any this long anywhere.
Measure your front springs from bottom to top (don't include the isolator). Anything over 12" is your lift height. You should be able to order new links based on that or get adjustable ones like JKS or something.
Thanks All. I figured out it had a 6" lift and was able to track down some links that should be correct. Had trouble finding the information I needed between this forum and google, but never thought about measuring the lift height to determine the correct length. Looks like they put rears on the front
Go on Amazon and type in 'Jeep TJ (what you are looking for)' and you should find it. So if you don't know what the part is just type in the system it's used for. So need a transmission bracket but don't know what the bracket name is? Just type transmission.
