Can't find tie rod end part
okay definitly will get currie but not sure if just the end or the whole tie rod. the tie rod seams to be very slightly bent.
the bend does seem slight, maybe you could remove the bar and apply enough pressure to move it back. replace the end and check it occasionally to be sure it's gonna keep. if the bend should reappear it's been weakened and needs replaced
Reactions: 06TJ35's
The beauty of the Currie tie rod system is it's ability to be straightened if indeed bent. Remove the long end and take to a shop that can press brake the rod straight.
Reactions: 06TJ35's
I am looking for a tie rod end part as well. The castle nut and pin fell out as I was on a trail, as a result I lost my steering. Does anyone recognize this part brand?
