I’m really not quite sure how to explain this. My no start in park issue is persistent. I recently had a mechanic replace my NSS which didn’t fix the issue.
I came out to the Jeep after work Monday to a dead battery, completely dead. I blamed this on the radio since smoke came from behind it and removed it. Seemed to have cured my issue.
I came out to the Jeep today after work to again, a dead battery. This time I jumped it and let it run, got on the highway and check gauges come on. Everything was normal aside from my battery voltage jumping up to the dot past 14, maybe a little higher. It kept fluctuating and when I came to a stop off the highway it went to normal and the check gauges went away. I start driving, it does this again and the check gauges light comes on.
I make it home, shut it off. My key is in the off position now. All my gauges start fluttering, it’s going “beep beep beep” as if I have the ignition in “run” without it actually running.
I’m really at a loss here. I don’t know if these mechanics messed with my Jeep somewhere as they told me my front end is falling apart and that they’d get rid of it if they were me. I highly doubt that but what are the chances? They did my water pump and I had to go back in two days later for brake line fittings leaking. Not even a few days later I begin having the issues described above.
Can’t catch a break with this thing. I’d really like to sell it but not the condition it’s currently in. Can anyone at least give me a few pointers? I’m not even sure where to start..
If it helps, I have a new starter, new NSS, I think my ignition control behind the actuator is aftermarket, I don’t remember if I stuck the Mopar one back in. Alternator hasn’t been changed as far as I know. Battery is from 2016. Any help would be much appreciated!
