Okay so I am bumping my front axle and trying to get it centered front to back. Going down the road my steering wheel is turned about 1/4 of a turn to the right in order to go straight. My passenger side controll arm is shorter than the drivers side arm by about a 1/4 inch. My spring perch on the passenger side is also about 1/4 inch further back than the driver side. I do not want to fix that spring perch I will have to just deal with that part. Now my question is should I center the axle under bump stops, center it by making both lower controll arms the same length, or try and get it centered by adjusting the controll arms to where both sides of the axle is in the same point under the Jeep. One last thing. The passenger spring is slightly bent forward more than the driver side which I expect but both springs are still curved.
