mrblaine, thanks for the "how to" information. I followed your steps, but made one change. I had trouble getting repeatable measurements to the plumb bob string. The track bar and/or steering damper interfered with the axle reference points I wanted to use, and I was too lazy to remove the steering damper.
I remembered I had a laser level with magnetic base. I put painters tape on the bumper, and marked the center. I stuck the level to the bottom of my bumper, on the center marks, and aligned the laser with the center body mount and my plumb bob string. With the laser set to project a plane instead a point, I had an easier time getting repeatable measurements. I didn't matter if I measured from the sway bar link mounts, brake rotors, or whatever, the axle was off center the same amount.
FWIW, my previous attempt to center the axle, I used the outer edge of my fender flares and tire edges for reference. Using frame/axle reference points, as compared to fender flares/tires, there was a 3/4" difference.
