I have a 2006 TJ with 4.0 engine and the 42rle automatic trans. I just changed my tires and wheels from 15" wheels with 31x10.5x15 tires to Moab 16" wheels with 31.5" x10.5 tires. I have not seen a huge difference driving it around town, but I am wondering if the taller 31.5 tires are ok with the auto trans and 3.73 axle gears. Looks like a lot of people put 33" tires on this set up without any problems. When I am going faster. like 60 mph the RPM seem to drop further. I don't know much technical info, but I assumed the Over Drive was kicking in and the RPMs with the taller tires drops more than before. I slo note that I have a dashboard switch that turns the Over Drive off. Should I turn off the over drive at higher speeds to keep the RPM a bit higher? Some may think my questions a dumb and that may well be true as I am not well educated on Jeep gearing and tire size effects. Thanks in advance for any info. I don't think it woul dbe worth it to spend over $1,000 to go to 4.10 gears but I know that would be best.
