I have bearing noise in the transfer case that has me stumped. I've researched some 40 hours chasing this down so any suggestions would be appreciated. I've seen threads in various forums with the exact same symptoms and no one has been able to pin it down. It's not the axles, clutch, drivelines, transmission, or transfer case shifter adjustment. All have been replaced/rebuilt/rebearing'd. When I rebuilt the transfer case, there was no visible damage to anything internal. I put in high quality chain and bearings. Everything was silent for 100 or so miles, then the noise came back.
Symptoms;
- noticable gear noise in 3rd, 4th, 5th on decel or accel. Gets louder as the oil is warmed up (ATF+4 or 10W30). The more load in the TJ, the louder it is. Like with two or more people.
- put it in 4WD, the noise almost disappears. When you go back into 2WD, the noise doesn't come back right away. Takes 3 or 4 seconds.
The noise is a spinning-shaft bearing growl. Never seems to get any worse but it's damn annoying.
Symptoms;
