Cheap drag link
it's the tie rod end, adjuster and drag link, don't know what you are seeing when you click
don't believe i need to replace the tie rod
If you just need to replace the drag link and not the adjusting sleeve or rod end, this would be the cheapest option you can find I believe, and would also ship a lot faster than quadratec. Saves you about 20 bucks. If you need all 3 components, then that option linked in op is actually 15 bucks cheaper than buying the three parts separately.
https://www.amazon.com/dp/B000C5406S/?tag=wranglerorg-20
the XJ drag link is virtually identical and much cheaper. Apparently there is a TJ tax. The only difference is the "flat section" with the hole for the stabilizer is at a slightly different angle. I've run two TJ's with the XJ drag link for several years...trails, rocks, street... zero issues.
