Got a 1997 TJ 2.5. 5 speed. I Just changed the alternator because the old one was seized up. After changing the alternator now the check engine light is on and the codes it giving is 37 and 25. Any help I’d really appreciate it. It did not have the CEL on before I began. All the gauges bounce to very irractic. I know this are the code but not sure where to begin and if it has anything to do with changing the alternator. 25** A shorted or open condition detected in one or more of the idle air control motor circuits. Actual idle speed does not equal target idle speed.37** Relationship between engine speed and vehicle speed indicates no torque converter clutch engagement. An open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit. Incorrect input state detected for the Park/Neutral switch. Auto only.
