So today up in the snow, I was in the middle of a 4 Jeep winch chain (took three of us to get enough traction to pull the stuck guy it was so slick) and when I was winching, the check engine light came on. I pulled up torque on my new android stereo and viewed the codes and saw the ones below. Searching the internet It seems to be an instrument cluster communication code, and per the information below a common cause is a bad battery... could the fact that this happened when my winch was pulling a bunch of power be an indication of a failing battery? The Jeep starts fine, and voltage seems fine... any other common causes to check?
