Just let my Rubicon down to check spring level. Rear has the OME shocks installed; front is just on
springs. It looks pretty level, but Trying to determine if I should add a space ring to front. Ideas? Any measuring points?
I just scrolled to line up your front and rear wheels which put your rear wheel about 1/8" higher than the fronts on my screen due to camera angle. Then I scrolled a little farther to line up the fender flares where the rear is about 3/16" higher on my screen so you seem to be leaning forward a little.
I'll say it seems to look fine in that picture. I'll also say my scrolling contradicts that. You need to at least get out a tape measure and measure from the ground up to the flares and see what it is. If it's less than 1" part of me wouldn't worry about it but part of me would.
All that and I don't even know what size spacers are available.
Good Luck and Keep on Jeepin'
the front is about 7/16 higher. I am going to go ahead with assembly. ThanksI just scrolled to line up your front and rear wheels which put your rear wheel about 1/8" higher than the fronts on my screen due to camera angle. Then I scrolled a little farther to line up the fender flares where the rear is about 3/16" higher on my screen so you seem to be leaning forward a little.
Thanks Chris.Looks damn good to me the way it is!
Don't worry about level, an experienced Jeeper on another forum used to say a level Jeep is highly over-rated. Truth is when you put a cheeseburger in the back or fill up the tank it wont be level anymore.
