That'd be the only axle I'd even worry about with a Dana 44 being up front.Rear axles appear to be in stock:
https://www.revolutiongear.com/prod...and_lj_rubicon_and_non_wdisc_brakes_30_spline
He has an LJ Rubicon so he has a Dana 44 up front. His stock 30 spline front shafts are more than up to tough trails with 35's and locker.I'm not sure why you would say that, given the Dana 30 has the same u-joints. I'd rather have both, like he wants
It's just as strong as the rear axle but being up front it seldom sees nearly the load the rear axle regularly sees.I thought the front was the weaker one.
Back when I was looking the website out of stock. I called and they put a set together. Have you called them?RG&A is out of stock till September. What other axle would be good to use for front and rear? Thanks
I’m near Santana RowIt is for non-Rubicons like mine, with a Dana 30 front. I just ordered the front chromoly Revolution axle shafts but I'm holding off on the rear chromoly shafts for my Dana 44 rear until I put a locker in it (currently have a TrueTrac LSD). Your Rubicon already has a locker, so @Jerry Bransford is probably giving you good advice to start out with the rear chromoly axles.
I'm waiting for a quote for the rear axle shafts and I can forward it to you if you're interested. Maybe I'll see you at Hollister someday, looks like we're both in the southbay.
They don't use the same U-joint. The older TJ Dana 30 came with Spicer 5-297X, the 2003 and newer Rubicon came out with the stronger and more durable Spicer 5-760x. They are physically the same size but that is where the resemblance ends. The Rubicon's 5-760x is a common upgrade for the 5-297X.I know what axle he has. I disagree. The u-joint ears are the weak point which are the same in both axles. It's rarely the inner shafts that break.
edit: Especially if it's an auto.
They don't use the same U-joint. The older TJ Dana 30 came with Spicer 5-297X, the 2003 and newer Rubicon came out with the stronger and more durable Spicer 5-760x. They are physically the same size but that is where the resemblance ends. The Rubicon's 5-760 x is a common upgrade for the 5-297X.
