On my 2004 rubicon, i have a factory cig lighter, and a factory power port. The cig lighter is blowing fuses at random times. its the proper 20 amp fuse, but I usually notice because I have a PHOOOONE charger in there (don't judge me Zorba) and it obviously dies when the fuse blows.
Are there any areas those typically short out at that I can check first? its def an intermittent short, I can put a fuse in and it lasts anywhere from 5 minutes to 2 weeks until i jostle it just right and it blows. The less I have to unloom the harness and the less I have to remove from the dash, the better. So if there is a common spot they short out, i'm all ears. Otherwise, i guess i'll tear the damn dash apart, again...
