I have a 98 TJ and I discovered my phone charger would not work in the lighter outlet. I probed it with my voltmeter and it was only putting out around 6 volts. What could be causing this?
Thanks,
Gary
Thanks,
Gary
https://www.amazon.com/dp/B00IRJH8CE/?tag=wranglerorg-20
Swap in one of these when you have the dash apart. And find the voltage problem. Roger ?
Unless it's a 6V lighter plug (seems unlikely since virtually every car charger accessory runs off 12V) you still need to work out the wiring issue.And find the voltage problem.
I know. I just wasn’t sure what could be causing the voltage drop and what to look for.
When I have the trim piece off to put the radio in, I’ll start at the outlet and work backwards until I find where the voltage drop is and address the problem.
And anoher thought is a corroded lighter plug. And lastly, an inaccurate meater.
