There are several versions available from 4 wheel parts, Quadratec, etc. They run about 300. I really like mine, just wish I could get it wired up again.No... But now I want one of these.
Tried that. Just didn't work. At this point I'm not sure that the head is even functional.I'll have to buy one at some point. Wish I could help with the wiring. Would it be too hard to figure out with a digital multimeter? Or is that even possible?
Yes. Just would like to see the wring diagram to double check stuffI wouldn't be surprised if after 9 years it failed.
I assume you've tried running power to it?
My wiring harness got mangled. This is an older auto dimming, compass, thermometer, with map lights. Can't find my install instructions and not sure where the power side of the harness attaches. Anyone have a copy of the instructions?
QUOTE]
Aren't they on the mirror?
Not the Gentex. There is no identifier on the mirror or case whatsoever. I am assuming it is a CIPA product because I bought it from Quadratec many years ago. When I trying to look it up on the website all they show is the new model that displays temp and degrees on the bottom. mine displays in a window in the glass.Is it the Gentex 177 mirror, if so I have one in the garage that I should be able to pin out for you.
No need to pay the price from Quardatec. I bought mine with the temp sensor and wiring pigtails for the sensor and the mirror from a pick and pull yard for $6. Made my own harness and it has been working for me flawlessly. Pulled it out of a Tahoe IIRCI'll have to buy one at some point. Wish I could help with the wiring. Would it be too hard to figure out with a digital multimeter? Or is that even possible?
