Looking for verification. My AC fan switch doesn’t seem to be working. Seems that no matter what setting the switch is at i only get air coming from the top defroster vents and the footwell. Am I right?
Verify that the switch is actually moving to different positions. Pull the knob to see if it’s cracked where it goes on the shaft, it will just spin if broken and not switch positions.
Mine was easy, but worth a quick check. Check the 4 lines connected along the transmission tunnel next to/above the gas pedal behind the lower dash trim. One of mine slipped there and it was a quick set it back on and be done.
Quick follow up. I decided to check the vacuum per Kids recommendation. First place i looked was the connection to the block and of course it was disconnected. Plugged it in and problem solved. Thanks for the help Kid!
