M mrluci New Member Original poster Joined Feb 6, 2021 Messages 1 Location Canada Feb 6, 2021 #1 2005 TJ, only happens when accelerating (sometimes decelerating) in 4wd. If this was a safety issue would it also be heard in 2wd? thanks! edit: actually I don’t know if I’d classify it as clunking. Last edited: Feb 6, 2021
AndyG Because some other guys are perverts Lifetime Supporting Member Joined Jul 30, 2018 Messages 18,902 Location Alabama Feb 6, 2021 #2 mrluci said: 2005 TJ, only happens when accelerating (sometimes decelerating) in 4wd. If this was a safety issue would it also be heard in 2wd? thanks! Click to expand... What you need to do is remove the front shaft asap and see what happens...likely a bad cardan joint in front ...and leave it out if it goes away and get all new joints in the front before it locks up and destroys the transfer case.
