I had the clutch slave/ master cylinder replaced due to a leak. Now, when I push in and let off the pedal it squeaks and rubs and does not feel smooth. I had the that installed the slave/master unit check it and he said that the piston is rubbing inside the master cylinder and there's nothing to be done. I did not have this issue with the old one. The new one, by the way is a Luk. I thought about removing the slave cylinder to see if anything could be done to fix the problem.
If anybody has any ideas about what is causing this, and a fix, it would be much appreciated. It's not so much about the noise, but it not feeling smooth during operation.
