was planning to replace all of my control arm bushings. Of course the first bolt on the first control arm is being stubborn as all hell and seems like the bolt has fused with the bushing sleeve. I probably have to cut it as i've tried to press it out with ball joint press which i think got bent in doing so (rental) I've pryed and chisled and basically destroyed the rubber of the bushing but the bolt basically stays in place.
What method for removing do u guys think'll be easiest. Kinda awkward for a sawsall, withh a cut off wheel through the center of the control arm or close to the inside bracket even work with all that rubber, or will a butane torch be able to do the trick.
Either way i gotta ride my bike to pick up whatever i need (after i fix it's flat) and am trying to get this out on the cheep. I'd like to be able to save my current control arm but me thinks i'll have to replace it,
