Currie upper control arm housing
https://www.currieenterprises.com/CE-9102K
Are these required to install curries johnny joint upper control arms? If so, was just confused why they weren’t included with their adjustable control arm kit. If not, does anyone run these and what are the benefits? thanks.
Currie is giving you an option for the axle side upper control arms front end joint. You can use the stock rubber joint that is there, or you can buy this kit and have Johnny Joints all around.
Reactions: 04RubiOR
