https://www.facebook.com/groups/crawlerfleamarket/permalink/3352820081694763/
Aqualu Aluminum Willy's tub, stretched, full tube chassis.
It has a Vin, registered and insured in NY.
-434ci Pat Musi SBC with holley EFI 600 hp at crank, dart block, holley heads, MSD distributor, remote oil filter.
-Griffin radiator and fan combo, multiple transmission and ps coolers etc. more than enough cooling for any terrain.
-full set of marine grade instruments, custom wiring and over head console controlling everything.
-PSC steering pump with dual reservoirs.
-Maximum Transmission, Reid TH400 Ultra4 spec build (billet internals, etc.)
-Hero 3 speed transfer case with 2.7 and 5.0 lows.
-Tom woods drive shafts 1350 joints
-Spidertrax axles, pro series unit bearings and knuckles, 40 spline 300m spidertrax shafts, Yukon super joints, Willwood 4 piston calipers,
spidertrax brakes, 6 x 5.5" bolt pattern, 5/8 studs, cnc hand brake, and cnc master cylinders,
Gear Works high pinion 10 inch center sections, polished Ring & Pinion, with spools. 50 degrees front steering, 40 degrees rear steer .
-ORI struts 14 inch .
-PSC double ended rams on both axles
-4 link rear, 3 link front with track bar aluminum links, FK heims.
-19 gallon Motobilt fuel cell.
-Odyssey battery.
-Steel braided hoses on steering & brakes.
-PRP xtra wide seats with lumbar, 5 point Crow harness.
-In cab heater .
-Rugged Radio's complete in car, as well as car to car coms.
-43 sx sticky tsl swampers (broken in) on 17 inch trailready double beadlocks.
-Competition LED lights as headlights & roof lights, it has rock lights, marker, brake, and reverse lights.
-Lexan windshield that is easy to take on or off as well as half soft doors and full soft doors as well as a rear bed cover .
-Warn 10k 8274 with synthetic line, factor55 hook.
-Spares:
43 sx on trailready double beadlock new.
Spare ps pump, alternator, starter, drive shafts, some steel braided hoses.
40 spline spidertrax stub shaft.
Used Yukon super joint.
I had this car built in 2009 and it's been raced, crawled, rolled, and driven all over the USA .
It's all been upgraded over the past few years and it's the most reliable well built all around rig I've ever owned.
It's done some of the most extreme trails from the Hammers, AZ, Utah, PA, VA, NY and tons of other places .
It's comfortable to drive at any speed and it has recovered and towed tons of people out of bad situations.
It's by far the greatest trail rig I can imagine.
My focus has switched to competition now with my son so I am ready to sell .
Tons of pics and videos at Big-silver4x4 on IG and FB .
a proven extreme rig ready to tackle any terrain .
75k or best offer
914 403 5686
Charlie Melchner
-Odyssey battery.
-In cab heater .
-Spares:
75k or best offer
914 403 5686
Charlie Melchner
