I've got adjustable lowers. My sye is showing up today, do I actually need adjustbale uppers as well?
2.25 lift soon to get changed to 2.5 in back and 3 in front.
I will get them at some point maybe next summer I just don't have the budget to do that too right now. Sounds good, thanks Chris!No, you don't need adjustable uppers. They just make the whole process sooooooooo much easier. I say this all the time... After having adjustable upper control arms, there is no way I would ever live without them. You can easily adjust the control arms while the vehicle is on the ground, tires on, everything. Can't do the with the non-adjustable uppers.
But no, you shouldn't need them.
Double adjustable uppers. Will do. What brand do you recommend? I like core 4x4 tier 3 arms a lot but they don't have double adjustable uppers. Preferably one with forged Jonny joints but I doubt it really matters that much
Metal cloak uppers have double adjustable?
I know your a Currie fan boy and I'll never understand it (kidding!)
Haha will do. I prefer Jonny joints as well but have opinion of the other.Metalcloak I don’t know about, but it’s worth checking.
Of course Metalcloak uses the Duroflex joint, not the Johnny Joint. I don’t have any experience with the Duroflex joint, but I am sure it’s okay. Just don’t tell Blaine you’re considering a Duroflex joint over a Johnny Joint.
The savvy ones aren't Bad, $285
Technically in his case he may actually never need adjustable uppers right? He could push with the lowers and if everything lines up he is good to go right?No, you don't need adjustable uppers. They just make the whole process sooooooooo much easier. I say this all the time... After having adjustable upper control arms, there is no way I would ever live without them. You can easily adjust the control arms while the vehicle is on the ground, tires on, everything. Can't do the with the non-adjustable uppers.
Who are y’all talking about?Technically in his case he may actually never need adjustable uppers right? He could push with the lowers and if everything lines up he is good to go right?
