While dialing in issues that weren't throwing codes (loose PCM connectors, this has been dealt with) I now have a new set to chase while dialing in this LJ (4.0L, 6spd).
I replaced the spark plugs (Autolite XP-985, gapped to 0.035) and all O2 sensors (NTK) last fall.
This week I did notice some power loss a few times, one of which definitely seemed to be due to heat soak - even though it's an 06 with the manifold shielding (I have the injector insulators on the way).
What other things can be involved? Is heat soak and a misfire likely to trigger the O2 sensor codes? Would it instead be the cats?
What's the best way to dial in on which it is? Should I add the insulators (arriving thursday), reset the codes, and drive a bit?
