Hello,
I have read many many post about misfires on the Jeep JK.
Let me explain my process and let me know your opinions please.
It started one morning driving my wife to work on the Highway the check engine light lit up, huh ok. I stopped to drop her off and noticed it running rough. So I drove to O'REILLY auto parts to use there scanner. It said #3 cylinder misfire ok fine. With 47,000 miles I will just give it a tune up and bought new bosch injectors, plugs and NGK coils. The Jeep ran great but still had the check engine light on. Went back to O'REILLY auto parts and it said RICH fuel, so I called a local shop to reset the ecm or set the trim. They called me back and said it will not let them set the trim. They suggested install the original oem injectors and replace the one bad injector in #3. I did exactly what they said.... the misfire came back to #3 (all new parts on #3).
So my question is.... why would it run great with the bosch injectors with too much fuel, then go back to the same issue with the old injectors??? Inspected all wires and Connectors.
Bad ECM???
Thoughts...
Thanks
Bad ECM???
Thoughts...
Thanks
