2001 Jeep TJ that I've had almost a year that I took of my dad's hands. I haven't got around to the engine yet but I've manages to rebuild the suspension.and do the rear main seal.
So the run down, I'm in Colorado it's been cold and windy. About 3 months ago it started doing the weird whining sound that sounds almost exactly like some of those videos with the cracked intake manifold so I've almost assumed it was that for a bit. Now thinking it could be the evap line I found. The whistle happens only at stop lights and when decelerating. I can't ever get it when I'm at home. The sound was only for the first few minutes of driving when it's cold out. I hadn't heard it in awhile.
Cylinder 6 misfire, pulled the plugs and they were pretty dirty. I assumed maybe bad gas and that maybe it was just their time to be changed. Replaced plugs with Champion double platinum spark plugs correctly gapped
I had also found the middle line at the evap cannister severally cracked. Temp repair done with electrical tape. (I assumed it was good since there was no code) valve cover also found to be leaking. Need to replace the gasket and clean the wells.
Now 1 week later Im driving and everything is fine. I park and when I go to start her up I get cylinder 3 misfire, I could barely limp her home. Before when 6 misfired she drove fine like there was no issue. This time as soon as I'd hit above 3,000 rpm I'd loose all power. Pulled the plugs and visually the threads are just coated in the copper anti seize and oil from the valve cover leak. I hadn't noticed that the threaded wells were thst dirty with oil.
I'm a very experienced helicopter mechanic so this should be easy for me but I feel like I'm over thinking this. I'm going to replace the plugs with the Autolights after I replace the valve cover gasket. I'm going to then clean the wells with some carb cleaner. I'm debating on upgrading the coil rail for a cleaner spark. (Likely will leave it) I need to wrap the injectors with some type of heat wrap since I've seen that technical bulletin. I've got a new evap line coming soon from Mopar parts.
Now that may fix the misfire issue. Still my exhaust has had a rich smell for awhile since my y pipes gone back on and there's still the whistle. I'm still worried that the y pipe isn't quite on there correctly or there's a cracked exhaust manifold or intake manifold. I'm probably over thinking it since I don't quite know the system as well as I'd like.
Any feedback or input is appreciated. I know these 4.0L are basically tractor motors that soak up heat lol
