SO I HAVE A 2002 TJ WRANGLER AUTOMATIC THAT I HAVE HAD ABOUT TWO YEARS . 6 MONTHS AGO IN APRIL I GOT A CHECK ENGINE LIGHT CODE FOR MISFIRE CYLINDER 6. SO I WENT TO BUY NEW SPARK PLUGS AND IGNITION COIL NEW AS WELL.CHECKED THE INJECTORS ALSO AND ONLY ONE WAS BAD AND SWITCHED IT OUT WITH A NEW ONE. ON OCTOBER SIX CHECK ENGINE LIGHT POPPED UP AGAIN SAME THING MISFIRE CYLINDER 6. RE DID THE SPARK PLUGS NEW AGAIN AND ALSO A NEW IGNITION COIL. CHECKED THE INJECTORS EVERYTHING FINE HERE. BUT I CANT FIGURE OUT WHATS WRONG WITH IT AND AT IDLE IT FEELS FUNNY AND IT JUST DRIVES BAD . IVE SMOKED TESTED IT SINCE I HEARD A LARGE VACUUM LEAK COULD CAUSE A MISFIRE BUT NO LUCK. IDK WHAT TO DO.
