So I've read and understand the torquing procedure for bolting the cylinder head to the 4.0L blocks. I've worked on a couple Chevy 250's.
The spec's call for 110/100 ft-lbs with dry threads.
I've been reading that using lube of any kind will reduce the requirement of torque by as much as 40%??
The specific lube of using 10W30 and just a light oiling of the threads reduces the torque in this 30 to 40% range.
Anyone follow or use this type of reduction in torque??
