I can try it. I’ve got nothing to lose at this point. The guy I bought it from said he changed out the injectors when he was chasing the same problem so the injectors are fairly new but you never know.
Yeah. It's not a popular test for our tj's for whatever reason, but an injector balance test is probably in order. You'll need a fuel gauge and a tester like this.While you have verified the injector is getting a pulse, you may still have a dirty or bad injector on cyl 4.
If you have voltmeter you can measure the resistance of the injector and compare to the others. If the coil inside it is going bad, it will have a different resistance.
If it is simply dirty, sometimes a fuel system cleaner will work. Chevron Techron, Seafoam, etc.
You can swap it with another injector and see if the problem moves to the new cyl as well.
You will most likely need new injector O rings if you do this as they become hard over time.
OK, so maybe still an issue then.I can try it. I’ve got nothing to lose at this point. The guy I bought it from said he changed out the injectors when he was chasing the same problem so the injectors are fairly new but you never know.
That sounds like a bad upstream O2 sensor. If you install one make sure to ONLY install an NTK or NGK brand. No store brands or Bosch O2 sensors!Man I’m not exactly sure about the mileage but I know it’s horrible. I’ll go through a quarter tank making a 30 minute drive. I did notice my exhaust smells strong. Like gas I just figured part of the bad gas mileage was because it’s lifted with 35x14 R15 swampers but yes, I definitely feel like it runs rich and sucks down that gas.
Would a cracked manifold be something you could visually check?
A collapsed lifter will knock. You would hear it.Do you guys think that since the jeep sat more than it ran that I could have a lifter going out?
