Almost all inner shaft failures I've seen aren't a quick "pop it out, pop it in". Most break right at the splines near the locker and rarely come out easy. Unless you're getting way deep into the diff on the trail, the ability to "quickly get back on the trail" is a bit romanticized.When I was ordering all my parts from east coast gear supply, they talked me out of the 30 spline for the reason above, outers are still 27 spline. Also god forbid you break anything, 30 spline won’t be easy to get again quickly. With using the 27 spline, I can put a stock shaft back in to get me off the trail and back home.
And I'll just leave this nugget here...
