- Price
- 00.00
- Location
- Farmersville tx
Need a stock Dana 30 axle shaft. Passenger side.
Farmersville texas
Farmersville texas
I may have one Keith. Let me go look. I broke the driver's side, so the passenger should be around here somewhere.Need a stock Dana 30 axle shaft. Passenger side.
Farmersville texas
Well, don't give up on me. I can't imagine what I did with that passenger side. I wonder if you could bend the ear back? Of coures, it would have to be pretty darn perfect, so it may not be worth the try. 20 ton press can apply a lot of pressure.Hey thanks Jeremy man thats sacrifice there getting in that attic. I bent the ear removing the front axle u joint with my 20 ton press before i found out i did it wrong. No problem somebody around here should have one.
Hope u are all doing well ... I like the progress on your tj .
I learn lots from your posts.
Like... 20 tons or so worth, right?Well, don't give up on me. I can't imagine what I did with that passenger side. I wonder if you could bend the ear back? Of coures, it would have to be pretty darn perfect, so it may not be worth the try. 20 ton press can apply a lot of pressure.
Come to think of it, yeah, that seems right!Like... 20 tons or so worth, right?
