First Post Here…
So, I have a 98 TJ presently running 3.73 on 30in tires. It has a 2.5 in. suspension lift and I will be putting on 285/75/16 tires, 32.8 diameter, 57 lbs + 21 lb. wheel. I think the 3.73 gear ratio is not optimal?
Question One: What would be the optimal gear ratio. (I am never going to 35s)
More… Rather than pour money into re-gearing a Dana 35, I am itching for a Dana 44. However, I have read here that the front Dana 30 is quite sturdy at a lower gear ratio.
Question two: So, am I right that it would be better to re-gear the Dana 30 to match, rather than put on a Dana 44 in the front… at least in the short term?
Thanks…
Thanks…
