Hey everybody,
1998 TJ Sahara 4.0 5speed, Dana 30 front, Dana 35 rear, 3.76 ratio?
I opened up my rear diff today to change the fluid. This is what I found. Video is attached below.
My question is what causes this and how do I go about replacing the pinion gear? If I pull on the wheels, the axle shafts do move in and out about 1/8 in. Is that normal? I also had a grinding noise from the rear when turning right which I suspect was the result of this. The ring gear and everything else looks to be in good shape, no chipped teeth or anything, just the pinion.
Thanks for all the help again! - Karl
