Dana 44 axle specs. Rebuilding an 06 TJ Rubi. rear axle housing was bent by previous owner. I had the housing straightened and I now need the tolerance for the axle shafts. The "wobble" on the drivers side (major impact site) is .045 and the passenger side is .015. I measured a new shaft and it is .005. I am assuming that the drivers side will require replacement, but not sure about the passenger side. Can anyone pass along some info on this? Sure would be appreciated. Thanks in advance.
