Okay. So I have the correct backing plate, seals, bearings and collar for my '05 Rubicon w/disc brakes. I've seen a couple of the pics on here and read the threads on how some have taken them to local shops to be pressed on and the shop making the mistake of thinking they know better than the owner how they are to be pressed.
With that said, will someone please clearly state all components proper place and alignment, starting with the backing plate (which I know its lip needs to face inward for the seal to seal properly) and working inward?
I am about to take mine to be pressed and want to be 100% sure that all is set as it should be.
Thank you!
Thank you!
