Height can't affect back spacing. The only part that affects back spacing is the thickness of the rotor hat where the studs stick through. I can't imagine enough variation there to matter.Does anyone have a set of OEM rear brake rotors for a dana 44 laying around that could measure the height or me? I bought an aftermarket set not long ago and want to verify that they aren't shorter since it would negatively affect backspacing and impact the task I'm working on.
@mrblaine?
That part on mine is 1-13/16Height can't affect back spacing. The only part that affects back spacing is the thickness of the rotor hat where the studs stick through. I can't imagine enough variation there to matter.
No it isn't. It is about .250 thick.That part on mine is 1-13/16
My measurement was based off this part.No it isn't. It is about .250 thick.
I was thinking this one would tell me.@Alex01 I have mine off right now. What measurements do you want?
Okay, I’ll go back out to my shop. I took this one. Give me a few minutes.I was thinking this one would tell me.
There goes that theory. 1/4" spacer it is.Here ya go.
Again, that dimension does not affect back spacing. It can't or the rotor won't fit.
