Wajeep TJ Enthusiast Supporting Member Joined Jan 27, 2021 Messages 124 Location Wa State Feb 12, 2022 #1 Is this likely a fuse or headlight switch issue? 97 wrangler 4.0.
P pagrey TJ Guru Supporting Member Joined Apr 10, 2018 Messages 7,725 Location Los Angeles, CA, USA Feb 12, 2022 #2 It seems like the fuse would be pretty easy to check?
CharlesHS TJ Expert Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 5,588 Location Jacksonville FL, Quezon Philippines Feb 12, 2022 #3 Headlight switch with bad contacts, headlight switch harness or the headlight dimmer switch rotated in wrong direction. The 1997 TJ has the same headlight switch as the 1998 XJ; the headlight switch is known to go bad....
