so..a follow up on the above stereo...
I ordered the above stereo and it took a while to get it. I picked up an 03 console to get it installed.
I am really not impressed with Seicane
I did not receive the radio I ordered. I ordered the WIN CE, what I received was the Android version.
When I went back to the website. all traces of the WINCE had been removed. So I figured I would give it a try.
https://www.seicane.com/hd-touchscr...l-control-mirror-link-1080p-tv-usb-sd-s23838e
the thing is basically a phone in the dash. so everything you start the car, it is not instant Music... it takes 2-3 minutes to boot. and it really wants to be connected to the internet. it was not too bad... good idea, badly implemented.
it came with all or the correct wiring to make it work, but none of the mounting brackets.
it only has 2G of memory. so you can't download a decent list through Spotify
it randomly locks up. in order to unlock it, you need to turn off the engine, then turn it back on. I later found out you can reset it using a needle on the front of the thing.
trying to auto adjust time, either through the network or using GPS it was always 2-3 hours off. I had to go in and set the time manually. but even then, it would occasionally change and be 1 to 2 hours off, then magically would change back.
I have contacted the company about getting it returned, all they want me to do is reset it.
We will see what happens
I have already removed it and replaced it with a Sony XAV-AX5000
I am already MUCH happier with it
