I installed a universal crossmember tranny mount under my AX-15 so I can drop my skid plate without supporting the drivetrain. It is hard mounted to the transmission & t-case and then has poly bushings at the frame. I feel like I read long ago that it's not a good idea to mix rubber and poly. Either motor & tranny need to be both rubber or both poly. I can't find that thread anymore though.
Is this true? If so, how big a deal is it? I've read it's pretty unpleasant to have poly engine mounts, and I couldn't find the right size rubber bushings for the crossmember. That said, if I'm risking cracking my transmission housing... I'll do what needs to be done.
