G'day Guys,
I joined this forum a year ago, but this is my first (maybe second, I don't recall) post, so be gentle lol. I also apologise if these questions have been answered before, I did have a quick search.
Last year I purchased my first Jeep, a 2005 TJ Golden Eagle. Because I'm Aussie, it came with the Dana 30 up front and the Dana 44 in the rear, geared to 3.73. Last year I also acquired a HP Dana 30 from a 96 XJ Cherokee (which is 3.07 I believe) and its my plan later in the year, to install it in the TJ. My ultimate goal is to run 33's (Australia has strict rules about tire sizes and lifts) with a re-gear to 4.56. I intend to use Revolution Gear ring and pinions when I finally get around to the install, and I have a couple of questions regarding parts.
1. I understand I will require thick cut gears for the Dana 44 due to a different carrier size used between higher and lower ratios. I know I will also require reverse cut gears for the HP Dana 30, but will it also require thick cut gears, or is the carrier size problem only with the Dana 44?
2. In regards to the Revolution Gear, ring and pinions, I notice they sell packages that come with master install kits etc. Obviously I would prefer this option to buying things separately. Can anyone tell me if the ring and pinions from the Dana 44 used in the XJs and TJs are the same? I'm asking because I can find packages for the TJ Dana 44/Dana 30 (which won't work because I need the reverse cut for the HP Dana 30) and the XJ Dana 44/Dana 30, but I don't want to buy the XJ package if the Dana 44 ring and pinion won't fit in the TJ diff.
If anyone is able to help educate a jeep newbie, I'd be grateful
Thanks for your time,
Emerson
Emerson
