Hi All, Thanks in advance for any input / ideas you might have.
Sometime in January my '97 TJ was sitting in the driveway running, my brother says he heard it rev up and then a pop happened. ( Wish I was there to help describe it better) And, that was that, it wouldn't start at all.
My dad is pretty handy when it comes to this kind of stuff so he did a lot of reading and came up with a game plan, he removed the head cap to make sure everything was functioning properly and all is well. Next we checked the distributor, we pulled it out and about half of the gear had been ground down to nothing.
So, we go get a new one from Advanced Auto, replace it (made sure timing was all good), and boom, jeep works again. It would backfire here and there I just thought maybe the gas had turned, or maybe the fuel pump wasn't working properly. I drove it for about two weeks like this, It would run fine, then hit a deadish spot (spit and sputter) then continue driving just fine.
Then, one day in the middle of an intersection the jeep decides to die on me. I can't for the life of me figure out whats going on. I let it sit a while and then it starts again, we get it back home and let it sit. Dad thinks maybe he didnt seat the distributor right. We go to remove it and it won't pull out easily, we almost needed to pry it out.
I wish I knew the correct terms, but the washer tabs were bent down onto the gear, so we think ok, bad part, take it back, replace it, install it. Back in business. I drive it 12 miles and this time it completely dies no restarting this time. We tow it home, go to remove the distributor and the same thing has occurred.
I'll upload a pic of what I'm explaining. If anyone has any ideas I'd really appreciate it!
