Will check when I do a diff oil change at 100kJack it up spin one tire by hand, if opposite tire spins in same direction it's LS, if spins in opposite direction it's open. this is not 100% as the clutches can wear out and clips break rendering your LS to become open. Fool proof way is to remove the cover and look... Probably time for an oil change anyway?
Clutch packs are cheap, like $80. do it yourself.How much should getting the clutches replaced cost?
depends on what you want to do with your TJ. Detroit make a nice upgrade to the LSD called the True-Trac, not overly priced. Serious off road you might want to consider a selectable locker if you still want to go back and forth to work.Is it worth replacing the clutches or should I just plan on getting locker at some point? I have heard that the 44 LSD is not very good anyway.
How many of those have you personally installed?Clutch packs are cheap, like $80. do it yourself.
I've never done it, but it definitely isn't a "unscrew this, remove, replace screw back in" type of repair.I know your not replying to me, but I haven't done any. From your comment I am assuming it is either not all that easy, requires special tools, or since it would be my first I am likely to screw it up and cost myself more than a new locker when I try it?
I've done 1. I know they can be a pain in the ass, but they are not that bad especially if you are like me and can't afford to pay a mechanic. If you are not mechanically inclined then by all means, take it to your mechanic.How many of those have you personally installed?
I tried it and it just says" No records found corresponding to the VIN provided " im sure im typing it in rightYou could start by taking a look at your build sheet. Enter your VIN here:
https://fcacommunity.force.com/RAM/s/equipment-listing
nevermind im stupid,, the I is a 1 lolI tried it and it just says" No records found corresponding to the VIN provided " im sure im typing it in right
I have confirmed I have a limited slip, and I have never taken apart my diff, im at 91k on the clock and going to do a trans and both diffs at 100k, so is that a yes that I do need a friction modifier?If you're worried that the presence of a LSD would mean you need to add the friction modifier additive, don't. It's hard to find a gear lube that does not have the additive since the additive is compatible with axles that do/don't have the LSD. You can confirm the presence of the additive on the back label of the gear lube bottle. If it says something like 'Compatible with limited slip differentials' that confirms it contains an adequate amount of the additive.
And not all rear Dana 44 axles came with the LSD. Some did, some did not.
Yes but by 91k miles the clutch pack for your Tracloc LSD has worn out so it can no longer act as a LSD. So there's really no more need for the friction modifier that is in most gear lubes anyway. The Tracloc's clutch pack is normally worn out by 50k miles or so.I have confirmed I have a limited slip, and I have never taken apart my diff, im at 91k on the clock and going to do a trans and both diffs at 100k, so is that a yes that I do need a friction modifier?
I did one when my wife had a Liberty.How many of those have you personally installed?
